so either it's lubricant, or it's hydraulic fluid. If the MC was failing due to a leak, it would be leaking continuously. MC failure would have symtpoms such as leaking around the hardlines, or squeaking under compression.
Bleed the system first PROPERLY (look up Gordos writeup) before you start replacing components.
